Again...Where Do These Go?
SgtSuperbird
12:25 AM
SE Michigan
Again, I'm working on a '71 RR that I didn't disassemble. Where do these eight firewall and kick panel insulation pieces go? I believe these are DMT products, however DMT does not have instructions or downloads for this. Thank you!
www.moparshop.com/Kick-Panel-Insulation-71-74-Mopar-B-Body
1) (Your #5 and ?) The 2 larger pieces that tuck into the body behind the door hinge area with the matt face up against the body.
2) (Your #1 & #2) The middle lower pieces that are glued to the back of the kickpanels using 3M yellow weatherstrip adhesive
3) (Your #3 & #4) The 2 middle upper pieces that are sandwiched between the body and dash mounting brackets above each kickpanel. The matte face goes against the body.
www.moparshop.com/Firewall-Insulation-with-Pins-E-Body-70-74-A-C
1) (Your #6 & #7) This is our NEW, correct shape, correct fit NON A/C firewall insulation / sound deadener for 70-74 E bodies; AAR, Barracuda, Challenger, T/A.
We improved the correctness in both shape and materials
www.moparshop.com/Firewall-Kickpanel-Insulation-w-PinsB-Body-71-74-Non-A-C
www.moparshop.com/Firewall-Insulation-w-Pins-non-A-C-71-74-B-Body
1) Shows your #8 but does not locate it.
3) (Your #2 & #3) The 2 middle upper pieces that are sandwiched between the body and dash mounting brackets above each kickpanel. The matte face goes against the body.
Perfect! Appreciate it very much. For all the searching I did on the internet - and even a call into DMT - this explains most of them pretty well.
I made an error on the upper #3 list. I corrected it to reflect properly #3 & #4
