rm6p
I cannot bleed the air out of the brake system after a caliper change. 1970 Roadrunner with power disc/drum brakes. The car was originally a manual drum brake car. I added a factory booster,master cylinder,metering valve, combination distribution/proportioning valve and calipers. Brakes worked great since the install and pedal bleeding 500+ miles ago. Noticed a leak on the passenger side caliper and found the piston seal was leaking. Replaced the caliper and cannot remove the air out of the system. All connections are tight and dry. Pulled MC from booster and no leaks out of the MC piston. The MC gets a little wet but not from the lines. Fluid seems to push past the lid gasket. I might just have too much fluid in the bowl. I can gravity bleed all the air out then try to pedal bleed and air starts again. The pedal bleed pattern is; very small foamy bubbles followed by a couple larger 1/4" ones. This repeats,repeats,repeats and never stops/ I have run through more than 48 ounce of the same Valvoline DOT3 as I used originally. Gravity bled again and have a very mushy pedal. Rebuilt MC Summit (A1) and calipers (Autozone). Has anyone run across this and have any ideas?
