Airgrabber base
sc440
11:46 PM
ohio
Just ordered a airgrabber base (69 440) it’s going on a 440 with a holley dp carb. These 2 tabs in the carb mount base I have circled don’t allow it to sit flush on carb do you bend them up? Looks like they are meant to line it up straight but not not on a Holley?
Bend them up or cut them off. Can't remember which I did.
They don't fit anything but a stock carb !! The purpose is to keep the base straight front to back.
what , if I may ask , did you pay for it ??
They had 20% off deal going ordered on Sunday was at my door in Ohio on Thursday
Have no issues with my Holley but using original base and 70-72 base
What kind of wingnut setup are you guys using? The one that holds the base to carb which is inside the aircleaner I was thinking about welding a washer to it big enough that it could never fall threw the carb and in the engine.
Factory stud but have used threaded rod and welded nut
I just use a long bolt.
