Alternator suggestions. 165 Amp?
I run 120 - 160 amp for EFI cars, currently running a 150A on my 5.7 in my 71 Charger. This came with the Holley mid mount kit and is recommended by them for the terminator X max system. While its true that most cars are not going to draw 150A the stability in current at that point is required with EFI and some ignition systems. Another way to look at it, while your car may never draw the full 150A (or more), it does not hurt you to have it however the opposite is not true (not enough power is detrimental to electrical components and reliability).
I'm also reading this on other sites that may be considerations:
Many say 140 amp ones will put out less at idle than say a 100 amp version. You need to output curve of the alternator to really know but it is a general rule.
Another side effect of the high current alternators is you can get belt squeal at startup when it jumps into high charge mode.
I have been reading that 150 amps running tnru the system, may have problems. My guide, other than boat wyring, is a book called Living on 12 volts. It is scary reading, and the subject is a lot more complex than I ever imagined.
In short, too many amps thru too small of wyring, can be a problem.
Ok, I should have been more specific in that in two cases I am running 120-16A alternators on brand new wiring harnesses with upgraded cables.
On the one other case (my 70 Challenger) I am running a 120A alternator with the original (but inspected and upgraded) wiring harness.
My 71 Charger (5.7 Hemi) uses a Holley mid mount serpentine system with a 160A alternator however my 73 Cuda is using a V belt system and a 140A alternator and my 70 Challenger using also using a V belt and a 120A alternator. None squeal on startup. Good wiring is a MUST as are good grounds, correctly made connectors, etc.
Lastly, none of my cars are using an Amp gauge but 2 of my cars are using the bulkhead connectors, the 73 has the wiring harness coming directly through firewall without a bulkhead connector.
call John at Powermaster. They can help. I run the biggest on they. Are and it bolts right in with stock brackets. Think max is 175 amp
Talked to Powermaster at PRI today. Of all the alternator vendors I talked to at PRI they were the only ones that refused to provide an output curve. They said we give you idle amps, cruising and top speed (or something like that) amps. I said need to know rpm vs amps. They shrugged their shoulders and were done with me.
Seriously? That is not what I expect from a professional alternator vendor. All others either showed me the curves or said they would email them to me. That is the correct answer.
