Texas charger 73
I am currently putting my standard dash back together, before I install.it I want to fix the ammeter problem. I will also be running a seoerate voltmeter just so I know how many volts I'm running. First thing in did is pull wire number 16,and number 20,from bulkhead as these seem to be the biggest black and red wires that run to the gauge. Correct? Next do I need to do anything to the wire from the engine harness side that plugs into bulkhead?,Dont need any live hotnwires? Next. Which stud is the battery stud and which is the ground? Next how do I hook it up to work?, I have read something about a fusable link and wire to the alternator instead of the battery? I want to do this once and do it correctly. Thank you for all help. What gauge wire and size fusable link I need?
Also what are the two plugs? They go driver or passenger side? Single plug brown wire, 3 plug looks like green,dark green and brown or grey.
This is on a standard dash 73 charger
