noz34me
Went to look today at another Roadrunner, a '74 with a 318 and automatic.
The Good:
My plan would be to have the body/suspension/drivetrain work done by shop/s. I can handle the interior as well as any electrical problems.
So given the above, what would you guys offer for it? They're asking $3K.
The Good:
- All body seams look even and nice- -even better than the (95%) one I looked at last week.
- Genuine Roadrunner Steering wheel in place and in perfect condition
- Door Panels in good shape
- Rockers look to be in good shape some rust but not through.
- Looks like car was originally beige or close to it, painted black but was probably a decent color change when it was done.
- All the glass appears to be in decent shape.
- Seats are all there. It's a bucket seat slap stick car.
- Dash, although kind of rough is complete and stock with radio, knobs, dials, gauges etc. It's a rallye gauge pack(full instrumentation, but no tach) It has the clock where the tach belongs.
- Trunk pan and floor pans appear solid although with surface rust.
- Around front and rear windows is near perfect; none of the usual rust around the trim that I've seen on so many. There is one rusty spot at right rear bottom corner of window.
- Passenger compartment appears to still be watertight.
- After being told they would charge the battery so I could start it, when I arrive no battery, and told it wouldn't take a charge.
- Could not get passenger door open, and not sure why, I guess the operating mechanism is not disengaging from the latch.
- Putty along the drip rails on both sides of car is cracked and coming loose.
- Car is completely stock, so would have to assume there will be brake and suspension parts that need replacing. Last on the road 2 years ago.
- Quarters and fenders all have significant rust through
- RH rear wheel well has a hole into the trunk that well you couldn't throw a cat through it, but a 12 year old fist would probably fit
- Interior needs a complete and thorough re-do. I want to change it to black anyhow. Dash pad is cracked so bad it's unrepairable- -
- There is, I don't know how to describe it other than a "tear" in the sheet metal right at the RH sail panel. Possibly with a full quarter replacement it would be replaced anyhow. Looks to me like some bondo work that experienced temperature differentials that cause it to crack. Ugly, Ugly, and I 've never seen anything quite like that.
- The whole bottom side is rusted, although not rusted through. Looks like it needs a good media blasting, which of course may expose some other issues.
