Geoff 2
R/grabber, post #11.
From memory, idle vac is about 11". Car has p/brakes & they work ok. I spent a lot of time dialling in the idle advance, which is 43*. It has a Mopar elec ign dist that fires a 4 pin HEI module, 0.060" plug gaps, & is revved to just under 6000 rpm, about the limit of the cam. In a 68 Charger, 5 or 6 gears [ I forget ], but will spin the wheels in 3rd gear. The dist had an adj vac unit, but the spring was too strong for the available vac. I swapped a spring out of an adj HEI vac adv unit, which is softer than the Mopar. Rock steady idle now with 43* at idle.
