WTB AO1 Light group
Robby442
1:33 AM
Doylestown,Pa
Feedback: +1 / =0 / -0
Looking for A01 light group option of 70 Charger B body in working condition. I believe they were same in 69-71 and maybe other years. Dash wiring sub harness with ignition key light, map light, ashtray light, trunk light, hood mounted turn signal indicators.
Map light, trunk light, courtesy lights, under hood light?
All new harnesses, lenses?
I got this light harness forget what it's for but came with a b-body Map light kit... $15 shipped if it's one you need..
I don't believe any company reproduces this A01 Option. It included ashtray, glove box, trunk and map lights as well as ignition light w/time delay, hood-mounted turn signal indicators and headlamp on warning buzzer. Don't think underhood light was part of it. Do you have or can reproduce?
I have a 68 in the yard with the AO1 stuff that I need to pull. Has the harness, map light and g/box light. Probably have a trunk light too. I found a ignition switch light that will fit the 70 column. Will probably be Monday before I can pull them and I'll get pictures for you.
I am looking forward to hearing from you and viewing any photos you can send me. I'm hoping that 68 will have everything and uncut harness wires. I attached a picture of a 69 ignition light(found on internet) and as you stated the 70 is different. Either way it appears in the picture there is some type of diode/relay(?) attached to the ignition light portion.
No sir, you'd be right though.
My bad. Been while since Ive owned an A01 car. Im sure the crew here can "Hook you Up"! (Literally)
I got the harness pulled from the 68. I also dug through my stuff and found three 1970 B dash harnesses that have the AO1 harness. That is as far as I got. I want to check and compare the 70 ones which I'll today.
So I do have the harness, map and g/box light. Still looking for the trunk and ashtray lights and trying to make sure I have the right i/switch light.
I also have two 1970 ones and they do not have the map light included. Looks like the map light harness that QuickBpBp has would work for 70.
So looks like 1970 is probably another one year only thing. I know 71 is different.
Thanks for the photos and info. I'm thinking maybe getting one 69 harness(which has map light) and one 70 harness to cover my bases. Just to make sure on the following: 1) Does the 70 harness have the correct 70 ignition switch(appears so?) 2) Does it also have the ashtray light and trunk light? 3) Also, since not familiar, doesn't the map light have a pot metal base(attaches to dash-example previous post) that bulb twists into and wires connect to that for on/off capability? If so, do you have the base from either 68 or 70 dash parts?
I'm working at yard today and will round up everything I have and get more pictures.
Ok, thanks. We're getting our warmup in northeast starting Tuesday. If when you send the photos you could respond to the 3 questions too that would be appreciated.
Here is what I could round up.
68 AO1 harness including the map light.
69 AO1 harness missing the map light.
7O AO1 harness good but the round connector is broken
70 AO1 harness good connectors but has been spliced.
68 ashtray light.
68 G/box light but the wire came out of light.
Sorry I don't have a trunk light. Think that 66-70 are the same.
Also I don't have a 70 ignition switch light which I think is 70 only.
Everything for 71 is different.
20210306_161115.jpg 20210306_161123.jpg 20210306_161134.jpg 20210306_161217.jpg 20210306_161222.jpg 20210306_161227.jpg 20210306_161145.jpg
