April Mopar Giveaway 2024-Phase III & III-A
73
Plymouth Duster
2dr coupe
F8 Forest green poly
Even though the roof is the same,the RL would be called a coupe,and with roll down glass I guess it would be a hardtop. like the did with the post cars.
1969 Plymouth Valiant, L1 Sandpebble Beige, 225 ci, 3 on the tree with radio delete and 14"wheels.
1) must be a GTX, RR, Belvedere, Satellite
or Sport Satellite (Satellite Sport Sebring), or a Duster
if it's a Plymouth (aided by hints),
you also said; you didn't drive a Valiant so out it goes
if we're (or I'm) not being thrown off by hints
2) Must be a 2 dr coupe if it has fixed rear qtr windows too
I ruled out Cricket, I assume they can't go 120mph
3) if so then it should be somewhere in 71-74-ish
are the only ones with fixed rear qtr windows
I can think of (aided by hints)
4) I'd assume it'd also be a model you could get a v8 too, min. of 318,
I'd also assume a 340/360 383/400 or 440, one of the performance models
to even go 120mph sustained for any time, probably 3.23:1 gear (maybe 3.55:1)
I don't think (?) the 'cuda or Barracuda or grand coupe in those years
had a fixed rear qtr window
not that I remember anyway (correct ?)
5) I went green colors because you said you like greens :poke:
6) it has rubber floor coverings so it's a lower end base model
that rules out GTX, Satellite & Satellite Sport/Sebring's, they are upper end
would have carpet at a min.
7) that leaves us with RR, Belvedere or a Duster
8) it's not white
am I getting close at all ?
on any of my assumptions
1973
