Phoenix440
I am installing reco iron heads on a 440.
Decided to buy ARP bolts, Felpro marine gasket, trying to avoid the previous leaks that were in the motor.
Was about to install one of the heads and thought it might be a good idea to make sure the bolt lengths are correct.
The long centre bolts with washer installed are exactly the same length from bolt tip to under the head ( washers installed on ARP).
The short ARP bolts with washers installed are a bit over 3/16 shorter than oem ( so this much less thread engages in the block).
The kit is AR145-3606 which is standard replacement.
I have contacted ARP, havnt heard back, but just wondering if anyone has seen this or did they mix up the bolts?
Any help appreciated
