At least the running lights work
jbearden
1:15 AM
Texas
Everything on my 1967 Dodge Charger works fine except for the driver side brake,flashers and turn signal.The passenger side rear and everything up front works flawlessly.I've checked the harness running to the rear,the turn signal switch and everything else I could think of.Could there have been something I missed in the turn signal?If you guys have any ideas,please help.Thanks ahead of time.
I swapped out the signal and harness and it started working.After I pulled the old signal switch apart I noticed that It looked like it was burnt around the dark green wire and only grounding out occassionally.It tested with a light,but it was because I had pressure pushing down on it making contact.Watch out for that if anyone else has simillar issues.
It's always ground. I had a problem with my back up lights. One would work the other wouldn't. It was the socket to the housing.
