- 3:30 PM
- Apr 13, 2012
- Granite Bay CA
Since I swapped from the 318 to the 440, I have used an external ATF cooler. Currently I have a 1970 Charger with a 440/493 and a Griffin radiator without an internal cooler.
I am converting to A/C and part of the project includes a radiator swap. The new radiator has a cooler built in but I am wondering if it is enough. I do not drag race the car, I run on the street mainly but do plan to run it on a road course in the future. I have considered running the ATF lines to allow the fluid to pass through the external cooler as well as the radiator. If I do this, should it be routed so that the fluid passes through the radiator first? Which line on the trans is the discharge and which is the return line?
Thanks.
Thanks.
