B block water pump confusion..help!
11:49 PM
Kansas
I have a 68 b body with factory air. after doin a radiator flush i soon sprang a leak from water pump area. My service manual mentions that a/c cars have a diferent pump than non a/c cars..i read online that a/c cars are 6 vein and non a/c is 8 vein with the a/c version is 30% overdriven. the pump i pulled off was a8 vein?oreilys only had 8 vein listed for my car? was wrong pump on car when i got it? It had overheating issues to start with. could this b some of it?
Are you suggesting that the A/C water pump has fewer veins but has a smaller pulley so it is overdriven 30% ? I had a chance to view a collection while travelling and took photos of several engines and I noticed that only one big block had a smaller pulley than the others. I'll check the photos for details.
yes. I found two different part#s for waterp pumps..ac and non.and the a/c does have a smaller pulley.but i found one forum conversation that someone claimed the 8 vein was for a/c,vice versa
a post claims that the 8 vein on the a/c(overdriven pulley) would move the coolant too quickly,thusv not alowing the system to properly cool. cavitate?
I've read the same thing years ago. And yes, you can turn a pump too fast and cause too high of flow and cavitation. There's a lot of info on the net on the subject of centrifugal pump dynamics and that's what you have on your car...a simple centrifugal pump.
the pulley is smaller by an inch or so. 5 inches and 6 for non a/c. o'rielys, autozone, and advanced do not have a six vein pump. the screen asks ac or non, but both pump numbers are the same? lol
In case anyone was interested i found in service manual that mixmatching pumps is illadvised and will cause issues..a/c equiped 383 have a 3.67'' 6 vein pump and non a/c use the 4.38'' 8 vein pump. now i just need to find one
big blk pump VANES
Here is a photo from my milk crates collection. fronts are large, rears are a/c small. Two style of impellers.
Note:
Vanes are blades on impeller
Veins carry blood
Vain is self pride that is unwarranted
I have run the 6 blade (as pictured above at the left rear) with a STD non A/C pulley and never had issues. It's claimed to be a high RPM HP increase to run an A/C pump on a non A/C car. I have even removed every other blade on the large 8 blade impeller and had no issues with cooling. However, if your pump is cavatating I believe that will lead to over heating because the flow is interrupted.
The replacement pump i bought from Advanced Auto is a six blade, but blades are larger than stock a/c pump. the orientation of blades are the other direction than normal..doesnt look like it will effect pump efficiency- blades are still flat, tabs are just bent other direction? It is a new pump, and part # is same for a/c- non a/c? thing the GMP brand pump would work ok?
