Don67Satellite
- 3:55 AM
- Dec 16, 2021
- Abbotsford, British Columbia, Canada
As @Geoff 2 said, more timing may help it to run a bit cooler, 12 isn't much for a smogger. You got a bump running those heads, but it's still low compression. I have a '78 440 with the 452's and I am running my Progression Ignition distributor programmed with 22 initial, 38 all in @3000 with 10 degrees of added vacuum advance. I used to run 14-16 with my old mechanical distributor, but increased it with this one after some research. It doesn't ping and it really came alive with that extra timing. With your setup you may not need as much as I run.
I also used to run a generic 5 blade "steel race fan" which I thought had good blade pitch, but I switched to a stock Ma Mopar 7 blade, and that thing really moves air.
With the current setup, it happily sits at 180 degrees unless it's super hot out and I'm in gridlock, then maybe climbs up to 185-195. But I did throw everything at it including the kitchen sink to achieve this.
