SOLD B body Dana 60
jamey
10:57 PM
PA
Feedback: +9 / =0 / -0
This is a B Body dana 60. 84.5 axle flange to axle flange. Apparently it was in a drag car with ladder bars. I will be cutting this off shortly. At the moment, I haven’t found the bom numbers. It currently has 4.30’s with a spool and 35 spline strange axles and 1350 yoke. Located in NW PA. $2000.
Sorry, you’re correct. Width is 58.5” axle flange to axle flange.
I cut the brackets off last night and wire wheeled the passenger tube and didn’t see anything yet as far as numbers.
I am interested - but the width is throwing me off. Everything I found is that width is significantly wider than B-Bodies. I do need a D60 for my 66 Satellite -
Rear End Widths
And if you get someone that wants the rear end but not the cover, I'd be interested in that....
Garceau that chart is from housing flange to housing flange. I measured from axle flange to axle flange. I can pull the axles and measure the housing flange to flange.
Cranky, that may be a possibility. I have been asked about selling the internals and axles but first I want to try to sell it complete.
Also have the ladder bar brackets cut off and getting the tubes cleaned up. There are no BOM numbers on the tubes.
I'm interested as well but trying to understand if it's an actual date period car housing. I need it for a drag car so I'm fine if it isn't, just don't want to pay a premium then. The big axles, spool, 4.30 is good for me.
It is a car housing. Has the provision for the pinion snubber.
Where are you located in Pa. ? I'm just south of Cleveland Ohio and I'm interested in it with no perches !
Corry PA. About 30 miles south of Erie
