B-Body Dana?
HEMIHUNTER
3:57 PM
Rhinebeck, N.Y.
Any way to tell if this came from a B-Body?
Measure the width! I doubt its a trk. but if it is it won't have a place for snubber! Casting number will tell you what it is for sure!
The BOM number should be on the right axle tube on the back side....may have to clean it with some medium grit sang paper to see them. You can then look up the numbers on the net and they will tell you everything about it.
as you look at my pic, on the right side of center where tube comes in I have a C34155 and a # 80 on the bottom right?????
And that looks like a 60 to me.....a cast in 6 looks really close to an 8 and the C3XXXXX numbers isn't the BOM number.
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-72 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
4.56 Powr-Lok 603109-6, -7, -8
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
74 E body 5.38 Powr-Lok 603425-1
77-78 Retail 4.10 Trac-Lok 603831-1
Axle Width Chart
Dana 60 rearend specs:
'66 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 U-bolt yoke
'67 B-body 54 1/4" housing, 59 3/8" axle flange to flange, 44" perch 23 spline power-lock sure-grip, 1330 strap yoke
'68-'69 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 23 spline power-lock sure-grip, 7290 yoke
'70 B-body 54 15/16" housing, 60 1/16" axle flange to flange, 44" perch, 35 spline power-lock sure-grip, 7290 yoke
'71-'72 B-body 57 7/8" housing, 63" axle flange to flange, 47.3" perch, 35 spline track-lock sure-grip, 7290 yoke
'70 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline power-lock sure-grip, 7290 yoke
'71 E-body 56 31/64" housing, 61 5/8" axle flange to flange, 46" perch, 35 spline track-lock
_________________
Check page 20 to 21 ...... I went their school in the late 70's.... Now if I could just remember.....Check out this web good info...
http://www2.dana.com/pdf/X510-8DSD.pdf
Axle won't have a mopar casting number, as the Dana is made by Spicer. It does have a stamping on the tube if I remember correctly. It might have had a paper tag with the part number on it also when new. As far as the width and all, the B-body Dana was:
Housing Width (flange-to-flange) 54.94"
Spring Seat Width (center-to-center) 44"
The spring seats would be the easiest to measure unless you took off the wheels and drums.
