SOLD B body Keisler 5 speed
68 HEMI GTS
6:36 AM
michigan
Feedback: +0 / =0 / -0
Keisler 5 speed set up. Probably only has a few thousand miles on it. It’s dirty from sitting. Guy I got the car from put it in there but didn’t really drive the car. I used it for a summer then went to a torque flight. Comes with modified Lakewood to work with the tremec. Clutch disc is good but the pressure plate needs rebuilt. Has cross member and Speedo cable for a 69 Plymouth. I do have an 8 3/4 drive shaft but in needs a yoke and u joints. I also have a Dana 60 dyno tech driveshaft with a mark Williams yoke that’s complete with 1350’s for a 69 Plymouth. You’ll need clutch linkage and a flywheel. 3k and located just north of toledo. 49270 Not interested in shipping.
0199D413-F45A-444B-BB04-38DDCFB711B8.jpeg 5D211313-F13A-4C40-A77E-E1214280E5B0.jpeg
Do you know the torque rating on this transmission?
trans is a TK2 which is a predecessor to the TKO’s. I talked to a guy at Liberty last year because I thought about changing out the 3.27 first to a 2.87 like a tko 600 if I was going to use it behind by 512. He said all the parts a basically interchangeable.
