B-body lock ferrule install?
Chad Hilburn
8:27 AM
Hey guys, this is a really stupid question, because it seems like itself explanatory, but on a regular b body with the metal upper door panels.You got the little chrome or stainless lock ferrules on top. Now, I've had mostly chargers, and those just kind of push in, but with these other ones, they make it look like they spring fit in, but they really don't. I think it's clear that you have to bend the tabs over hard. What's the trick that you guys have used to do this? Because it seems awful hard to get them tight and not make noise. I've seen these original not move at all. Has anybody figured out a good trick on this?
Do you have reproductions or originals?
Originals are chrome plated metal that will rust.
Drop it in the hole and use a dental pick to bend the tabs over, install the pull knob. If you can hear that rattling... you need more HP.. LOL
That said, the reproductions suck!
Those things look like this. When they pop in the holes those tabs should have enough sprinr to spread back out and grab the sheet metal.
That explains it. My Bee'sOE's were good and tight. Repros when I did the Bird, as the OE's legs were broken off, sucked the big one.
See now that makes sense to me but the aftermarket ones have 4 legs bent the opposite way they do on push in nor do the have legs that spring hold them in place
Those things look like this. When they pop in the holes those tabs should have enough sprinr to spread back out and grab the sheet metal.View attachment 1949237
I needed these for my 62, impossible to find.
After a generic ebay search I found later Ram truck ones that were identical, 'nos,' and dirt cheap.
Maybe other years/models are the same as yours.
NOS would be made the least expensive way as long as they look right installed. The OE ones would have been made with fast efficient assembly in mind - so they would have spent the extra penny to have the legs pre-bent.
