Paul Secoy
Hello all, I am building a stock stroke 400 B engine, and am having difficulty in locating an aftermarket rod that is stock length, but uses the now common .990" piston pin. It seems all I find either use the older, bigger Mopar pin, which limits piston selection, or they are an odd length intended for a stroker combination. I would like to find a rod set in the $500 range, which is easy to do it would seem except in my case. I've spent 2 days looking, and would really appreciate any help you can provide. Thanks, Paul.
