Zeppelin264
Hello, I'm battling this weird electrical issue that I just cannot figure out. I have a 68' Coronet and using the stock style starter relay with the post which I'm using like a junction box to power the Sniper and a few other things (I know this isnt a good idea, re wire is coming soon). Whats weird is battery shows 12.6, alternator lug shows 12.6, starter relay post shows 12.6 etc... I start the car and the voltage at the alternator and starter relay post are jumping all over the place. 2v, 3v, 8v, 14.5v, 12.5v. The battery maintains around 13.5-14v as expected.
I started hunting down all the grounds and they all seem to be clean. I have many grounds between the block and chassis, also a ground from the 1 wire alt to the engine block. So my questions is: could the starter relay be grounding out internally and making the whole electrical system jump around like this? This has to be some kind of grounding issue as its only happening when the Sniper is running the engine, otherwise, everything shows battery voltage when car is off.
I even went as far as disconnecting the alternator, fire the car up and it does the same thing, just without that 13.5v+ input. Was thinking it was a voltage regulator back feeding or something. I also have a few relays in the chain of power for the Sniper unit, could a bad relay do this and still function? Maybe its the Sniper unit itself, it is brand new, just got it fired up last week. Its the Sniper 2, I had the Sniper 1 and it ran fine for many years and just decided to upgrade it recently.
