Flickering/surging headlights.
Koenig1425
4:24 PM
Cheyenne, Wyo
My 64 Ply Sport Fury was experiencing flickering headlights. The headlights would dim/flicker at an idle (850 rpm). Once the engine came off idle the lights would shine without flickering. Also, the amp gauge would mimic the light flickering.
So, I read and reread a lot of FBBO posts, watched U-tube videos and read many Factory Service Manuals (FSMs). Checked all the wiring, Amp Gauge connections, bulkheads, connectors and every ground with a voltmeter and visually. I ensured the VR and alternator were grounded.
Based on the unavailability of round back alternator, I decided to install the newer electronic VR, and square back alternator, which meant installing new wiring, VR, and the square back alternator. There was no change in the flickering lights, but at an idle with all accessories operating the car would charge. An upgrade!
More research (reading FBBO posts/watching more U-tube and reinspecting stuff) and found some issues w/the headlight wiring. So, ordered a headlight wiring relay kit. Installed the kit and nothing changed, except the lights were brighter. Another upgrade.
Replaced the VR and alternator with no changes. Also, whenever a connector or a connection was moved/replaced, it was crimped, soldered and heat shrink installed.
Then added a relay to supply the MSD ignition signal the electric choke and added a second relay to supply alternator power. Both relays used the starter relay post for battery power. No change in the lights.
The bulkhead connectors leading to the amp gauge were removed using 10-gauge wire. The flickering intensity decreased but was still noticeable. Maybe I missed something else.
Then I remembered, “load placement matters.” So, I moved where the choke relay received its power…not the power that switched the relay…to the alternator stud. Then I moved the constant power for the MSD box to the alternator stud. Again, the flickering decreased.
What did I miss? Looking at the headlight wiring again…decided to move the headlight relay switching wire directly to the bulkhead. Just to eliminate another connection. Moving that connection, the radiator support head light ground wire (by the battery) required to be removed. After I removed the screw, I noticed the screw was rusty. I sandblasted the screw, and cleaned the radiator support ground hole, and reinstalled the ground wire.
Not sure the ground was the sole issue. But rather a bunch of little issues contributed to the flickering lights. The best part? I was able to use this forum to research/learn about the issue, rewire the charging system and ultimately fix the problem. Learning has Occurred! Thank YOU!
A second relay to supply alt power? Not following...
I installed a relay between the Alternator blue field wire which is fed 12 volts from the ignition switch. The blue 12-volt wire is now the signal wire for the relay. The power now feeding the alternator comes from the starter relay stud which as you know comes from the battery via the starter. This eliminated the ignition switch as a potential issue, even though it was new. Probably could remove that relay. One less component to fail, and fewer connections. Thoughts?
Have you added some relays to your headlights?
Yep, Did the crackback conversion. The problem is solved as of now. I just removed all connectors and cleaned them again! Thanks for the response.
I had same problem on 72 Plymouth. Tracked it down to corrosion on wires underneath coating. Copper was brown with green even though outer coating looked good.
Replaced wire, connectors and plug on regulator (those can spread contacts and get intermittent connection). Had previously removed ammeter and ran solid wire thru bulkhead.
I put positive and ground hubs under the dash and next to the battery.
All the grounds in and around the engine compartment get their ground wires extended and attached to the ground hub next to the battery.
Then run the incorporated pigtail from the battery ground wire to the hub.
Keeps a thousand wires off the battery, moves away from rusty body grounds, and results in brighter lights.
Fwiw on my 64 the front driving/directionals were not very bright, ground wires to the housing solved it.
Pardon Our Interruption
My '69 Dart would do something similar, but usually lost the headlights. My problem was the dimmer switch.
