Dave145
Hi everybody,
So my 64 Polara had had a wonderful vibration since I bought it. It's felt in both the steering wheel and front floor, and at all speeds between 40-75, while accelerating, cruising, decelerating, or braking. At 75 the car feels like it's going to explode with how bad the vibration is.
First I replaced the rear u-joint and rebuilt the ball and trunion joint. No change.
Then I changed the 4 year old tires out to tires that are a year old with 1,000 miles on them. No change.
Then I replaced all 4 front bearings and the 2 outer rear bearings. I also rebuilt the brakes at this time. No change.
I then replaced all 4 balljoints. Again, no change.
The shocks are newer (installed by PO and have no receipt but they are shiny). They appear to be el cheapo Monroes.
The tires are balanced with balancing beads. The car they came off of was my '76 Dodge Dart. That car shimmied at 75 also, but the rims had a bit of run-out to them. That car DID NOT vibrate as much as this one does.
So...I'm at a crossroads. What do you think it is? Steering feels tight. Tie rods feel a little notchy if you try to rotate them by hand, but I can't imagine that's setting up a whole car vibration.
Perhaps these rims are junk and seriously bent?
Tension bar bushings? Torsion bar bushings? Control arm bushings?
I don't think it's the rear end or axle, as while cruising I can drop the car into neutral and it still vibrates.
