Balancer Timing Mark
1toolguy
2:36 AM
Lakeland FL
Yesterday I used a piston stop (heads are on so it's a screw in style) to verify TDC. I set the timing mark at 10ATDC and screwed the stop in, I rotated the crank until it hit the stop again at 2BTDC. I did this procedure a couple of times with the same result each time. By my math this is telling me that my timing mark is off about 6-degrees, which would explain why my engine seems to prefer 20 degrees of advance over 14. Does that sound right?
You need to rotate the engine until it stops, then rotate in the opposite direction until it stops.
You will have two marks, split the difference and that's tdc.
Sorta what he did. If the results keep showing the same, probably right.
Don't know these days, but they used to make off-set keys, to correct that on balancers.
I would remark the balancer outer ring for zero. Also, continue the mark to include the inner to verify the outer is not slipping.
Great idea on the inner & outer markings. I'd mark the new "0" at the timing chain cover pointer or apply a new timing tape. That way it would be easier to see with a timing light. If you just remark the balancer, you still have to do the math. I'm too old for all that math.
