BB 727, B-Body 8.75 rear (Kentuckiana area)
blasphemous
New Member
6:17 AM
Louisville, KY
Feedback: +0 / =0 / -0
I'm looking for a BB 727 transmission for a cast crank 440. I need the flex plate also if possible. If you have a converter also, I'm looking for something with 3000-3500rpm stall.
I'm also looking for a 8-3/4" rear axle. I'm not picky on the gears, they don't even HAVE to be there. As long as it has axles and I can set the car on it, that's fine. The more complete the better though.
I'm located in Louisville Kentucky and would prefer to find someone semi-local unless you're willing to ship it.
Trans and flex plate are the same, but the converter has to be balanced for the cast crank. You can get a neutral balance converter and add the weights to it so it's balanced for your crank.
just fyi
I have an 8 3/4 housing with axles and backing plates for 11" brakes. I'm in Cleveland but sometimes get to southern Ohio on business. How far are you willing to travel? Coming to the Norwalk mopar meet this fall?
69 runner: Thanks for the tip. I didn't know about the neutral balance converters.
1Dart2NV: 3500-3800 is a little more than I'm looking for, but I'll keep it in mind.
gregs70: I go up to Cincinnati once in a while. Do you ever come down that far?
