BB Comp Cam for sale with lifters
Red63440
2:01 AM
NY
Feedback: +3 / =0 / -0
Comp cam 21-223-4, low mileage. Boxed with lifters as they were removed and numbered L/R with position. 125.00 plus shipping. Selling due to changing out to a bigger cam. Cam was installed prior to buying the car and cam has about 300 miles on it. Will come in a Mopar box.
Hydraulic flat tappet
Basic Operating RPM Range 1,600-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 230
Duration at 050 inch Lift 224 int./230 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 280
Advertised Duration 268 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.477 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.480 in.
Valve Lift with Factory Rocker Arm Ratio 0.477 int./0.480 exh.
Lobe Separation (degrees) 110
Camshaft Gear Attachment 1-bolt
Computer-Controlled Compatible No
Grind Number CRB XE268H-10
Valve Springs Required Yes
Quantity Sold individually.
Notes Single-bolt camshaft.
$100.00 plus the ride...
