Bellhousing for 62 with A833 ?
matthon
11:20 AM
New York
62 Dart, 383, A833.
I determined, after calling Brewers, that I need this bell: http://www.brewersperformance.com/proddetail.php?prod=BH513R-S
It hasn't been available for a long time.
Is there a stock/used bellhousing # I can use?
BH513RS-719 FOR 1962-65 B-BODY APPLICATION
BH513R-S BIG BLOCK 10.5" BELLHOUSING 1962-1974 A/B/E-BODY, 4.354" RETAINER, NEW
New reproduction 10.5" big block 356 T-6 heat treated aluminum bellhousing to fit 1962-1974 383/440/426 HEMI A, B & E-Body applications, 4.354" bearing retainer opening, use with 130 tooth flywheel. Bellhousing includes new clutch fork pivot bracket. See BH513R for 4.805" bore bell housing.
Bueller? Bueller? Bueller? Bueller?
I did call them to ask about a 62 bell, and they said the 62-65 was out of stock.
I'll have to call them back and ask about the 64 bell, which is in stock, makes no sense.
I didn't specify aluminum or cast or new or used, just a 62 with an A833.
I know 62 is different in some areas, like k-frame and engine mounts, but the bell should be the same, I would think.
We even discussed that the shifter may need to be bent for the 62 dash, and I would need to modify the trans mount.
I'll call them tomorrow.
