Bench test rallye gauges
USatC
10:21 AM
Montgomery
Okay guys I pulled my gauge cluster and now i’m a little lost for how to troubleshoot. In my Chrysler manual, they make note of a testing unit that I do not have. My question is does anyone know of an effective way to test the gauges in my 72 Rallye cluster.
One critical thing I believe it NOT to run 12V directly to the gauges. There is a voltage limiter in the dash circuit (often goes out) that drops the voltage down to 5V (or 7V, can't remember). If that limiter is good, then run 12V through the limiter & ground the other end of each gauges circuit.
I vaguely recall seeing something (on youtube) about somebody stacking together regular household batteries to use as a power source to test temp/fuel/oil, so maybe check that too. I really have no idea how to test an amp meter.
I have some old notes when I checked my 1969 rally gauges with the 5 volt linear (7805 type regulator):
Oil Pressure:
0 PSI, 74-82 mA, around 51 to 43 Ohms.
15 PSI, 108 mA, 30 Ohms.
20 PSI, 113 mA, 28 Ohms (2, 56 Ohm resistors in parallel.)
40 PSI, 136 mA, 20 Ohms
60 PSI, 156 mA, 16 Ohms
80 PSI, 172 mA, 9.79 Ohms (10 Ohm in parallel with a 470 Ohm resistor.)
Fuel Gauge:
Empty, 51 Ohms
1/4 Tank, 50 mA, 33 Ohm
1/2 Tank, 100 mA, 20 Ohm
3/4 Tank, 125 mA, 15 Ohm
Full, 150 mA, 10 Ohm
Temp Gauge:
120 Degrees, 62.1 mA, 62 Ohms
150 Degrees, 98.8 mA, 33 Ohms
170 Degrees, 119.7 mA, 22 Ohms
180 Degrees, 130 mA, 20 Ohms
225-230 Degrees, 160 mA, 13 Ohms
240 Degrees, 163 mA, 12 Ohms
just to check if they work, a 9 volts batt will work, or even 2 AA batts in series to get 3 volts... if using a 9 volts batt for a second to watch the needle moving, because as mentioned, they work with 5 volts.
to calibrate, thats another stuff
Just run the pos and neg from the batter to the two post?
Check post 3 here. Maybe it can help...……
https://www.forabodiesonly.com/mopar/threads/73-dart-swinger-instrument-cluster.423449/
5 volt supply? How about an old "wall wart" that you can verify puts out 5 Volts DC??
I use the old Heathkit power supply set at 5 VDC.
Yes.
You can make it also with an old phone wall charger. The old ones ( not USB ) uses to be 3.7volts or so.
Or if you have an USB with ends easy to attach to the gauge posts
Or any other power source on that DC rate. But if some source is above 5 volts, keep an eye on gauges, because you could get burnt gauges ( the 9 volts batt test needs attention ). Barely feed them enough to watch the needle move. Will move fast
you can also test the voltage limiter at the time. Feed it with 12 volts to check if the output gets a pulsating signal... no matter the speeds of the pulse but just getting pulsating signal. That will test good. If no signal or even worst, steady 12 volts, will mean is damaged.
Voltage limiter pulse speeds change between limiters, some are faster and short time pulse some others are slower and longer pulse. That's calibrated with speciall tools ( osciloscope I think ). The 5 volts is an RMS ( average ) measurement within pulses
