splicer
- 12:01 PM
- Jul 24, 2011
- Plattsville, Ontario, Canada
505 cubic inches? She is out of air by 5100-5300 rpm. To get the best out of it I would try shifting no higher than 5500 rpm. What's it taching through the lights, 5400 rpm?
Here is the reality of the whole setup. The RPM head OOTB is only going to flow about 275 cfm at .546" lift (.570"-.024" lash).
I have tested a very mildly ported RPM head with flows of 290 cfm @ .600" lift. With an Edelbrock Torker II and a 1.56 venturi carb, that combination only flows 264 cfm @ .600" lift. With the Edelbrock RPM manifold, 251 cfm. The M1 single plane, 266 cfm. The Edelbrock Victor, 271 cfm.
There isn't enough air there, with 505 CI, to make any more power beyond 5300 rpm.
I appreciate your feedback and am sure that you're probably correct....I would like to know the math involved to relate engine displacement and head flow to RPM for my own edification...
I'm considering installing a Holley Street Dominator....Do you have any info on one of those ? ...and yes it's at 5400 thru the lights....
Thanks again to all
Splicer
