best intake for 71 340 roadrunner
340bird
5:17 AM
Centralia Illinois
Building a street/limited strip 340 for my 71 roadrunner but Building it very old skool so which would be better ld340 or tm5
Take a look at the Lunatti 703 cam. Depending on your compression ratio (10:1) it would be worth a look. You might also want to increase your converter stall (3000-3500) JMO 440'
that is what im leaning towards looking to run around 4.10 gears and probably 2500to2800 stall, undecided on cam atm
motor supposedly fresh 40 over motor, they wasn't sure cam size and looks to be fresh j heads, im gonna pull it down so i can know for sure compression ratio and go from there, would love to be around 450+ horse
The dual plane intake may rob you of some high end power judging by the build numbers posted here.
