TheStoryoftheYear
I'm finally getting the motor pulled this weekend on my 72 charger se. I already bought the replacement floor pans and sheet metal.
What is the best order in which to do body work and paint?
My current plan is do the exterior metal work then strip the exterior and sparay it with epoxy primer. Then cut out the floor pans and replace them and prep the interior before spraying with epoxy primer. Then sand the the primer overlap and move into blocking and sanding before spraying with a regular primer and then color.
