FOR SALE big block 62-65 b-body engine mounting package usa made new!
WILLIAM COWGER
1:37 AM
APACHE JUNCTION AZ
Feedback: +0 / =0 / -0
MOPAR 1963-1964-1965 B-BODY IE DODGE 330,440,POLARA(not 1965 polara), CORONET 361-383-400-413-426W-440&PLYMOUTH SAVOY,BELVEDERE&FURY(NOT 1965 FURY), WITH THE FACTORY V-8 K-FRAME(273-318-361-383-413-426W K-FRAMES ARE THE SAME)
MOTOR MOUNTING PACKAGE; INCLUDES
2 MADE IN THE USA STEEL ENGINE MOUNTING BRACKETS(EXACT DUPLICATES OF THE FACTORY MOUNTS)
2 RUBBER MOTOR MOUNT INSULATORS RIGHT&LEFT
7/16S SAE GRADE 8 MOUNTING BOLTS, LOCK NUTS, GRADE 5 WASHERS
1/2 INCH WASHER&GRADE 8 NUT TO ATTACH RUBBER MOUNT TO BRACKET
4 SAE CAPTURED SPINNING WASHER NUT COMBOS TO ATTACH THE BOTTOM OF THE RUBBER INSULATORS TO YOUR K-FRAME. $150
YOU CAN REPLACE ANY 273 OR 318 WITH A BIG BLOCK V8 WITH THESE MOUNTS(I INCLUDED A PICTURE OF THE CORRECT V8 K-FRAME)
DO NOT FIT 6 CYL K-FRAME, YOU MUST DISCARD YOUR 6 CYL K-FRAME AND REPLACE WITH A 1963-1965 V-8 B-BODY K-FRAME
00y0y_3chYoGMjWYdz_0CI0t2_1200x900.jpg 00000_jgMRdQsQ2l3z_0CI0t2_1200x900.jpg 00m0m_8GFH4a7itFQz_0CI0t2_1200x900.jpg 00k0k_kemblKWmBPUz_0CI0t2_1200x900.jpg
curious what brand the rubber insulators are? Going to need to replace my old ones soon. thanks
