Big Block bolt dimensions
72sat
New Member
2:05 AM
st, louis
where can I get bolt hole dimensions for B,RB blocks? spacing for main cap bolts,oil pan bolts. would like to have the bolt hole dimensions for the both blocks. THANKS
B & RB are the same dimensions as far as the bolt patterns for oil pan rails
& 2 bolt main caps for both wedge blocks...
sorry don't have any drawings
you could buy a block girdle, windage tray &/or oil pan,
which is I assume is why you want the dimensions in the 1st place...
maybe you could get it from a girdle or pan mfgr. co., I kind of doubt it thou
try the guys at www.440source.com Maybe ??
I searched Google with differing criteria I couldn't find it
Maybe try http://www.allpar.com/ or www.MyMopar.com
try any of the Chrysler specific historical sites ??????
there are a ton of links on the bottom of this page you could try,
contact someone they may help you
{kind of doubtful from a business aspect thou}
http://www.moparts.com/ main index
Just curious, why do you want them? If you are thinking of machining your own caps or girdle, for example, I would think you'd want to confirm your measurements or better yet, take your own measurements from oem pieces.
