WTB Big block pulley
Matt B.
3:19 PM
Ellendale
Feedback: 1 / 0 / 0
I am looking for a big block non ac water pump pulley.
Matt B
Year? Manual steering=Single groove or Power Steering=2 groove.. PM me
You got a # or dimensions? I should have 1.
Don’t know what the # would be. Non power steering, so a single grove. I would use a double grove if need be. Thanks Matt
P.S. it’s for 71’ Roadrunner 383
If your crank pulley is 7", you will need a 7.25" w/p pulley to keep the 0.95:1 pulley ratio intended for non a/c 383's and a 4.38" diameter w/p w 8 vanes.
My car is originally an ac car. Was going to use the crank pulley. Guess I can’t do that? If not I will need a crank pulley also.
Matt
Matt
It's simple math. Divide the diameter of your crank pulley by 0.95 and you get the diameter w/p pulley you need. Over cooling won't hurt either though. Divide crank pulley by 1.4 and that's the w/p pulley diameter used to cool a/c cars but with a 3.5" diameter w/p w 6 vanes.
My crank pulley is 7 1/4” dia. So, I believe that I need a 7” water pump pulley.
Thanks MattB
My 1975 225's factory WP pulley (single groove), fan spacer, and 7 blade fan all are working out well on my 383.
Matt B
Here is what I have. Water pump pulley 6 7/8 diameter x 2 11/16 tall. Big block non ac.
2 groove crank pulley. Big block with power steering. 6 11/16 diametet x 2.5 tall.
It's simple math. Multiply the diameter of your crank pulley by 0.95 and you get the diameter w/p pulley you need. Over cooling won't hurt either though. Multiply crank pulley by 1.4 and that's the w/p pulley diameter used to cool a/c cars but with a 3.5" diameter w/p w 6 vanes.
seems you would want a smaller water pump pulley with ac so it would spin faster, do mean divided crank pulley by 1.4 would give a smaller 5 inch pulley ? my ac pulley is 5 inch
Yes, you are correct. I mixed up the 2. I'm going to edit, thanks. And the reason for smaller diameter pump n fewer blades for a/c water pump is cavitation. However I use 1.4:1 ratio w a Flowkooler high volume w/p but also use Water Wetter and have had no issues. But when keeping stock, I prefer to go w what the engineers designed which is what the attachment above shows. Thanks
Hunt2Elk are those for sale? If so how much?
MattB
Thanks to Hunt2Elk I have a set of pulleys coming. Thanks again for all the help everyone.
Matt B
