Bleeding Brake Calipers
mpro69rr
8:04 PM
Florida
Hey Guys, I have Wilwood brake calipers on the front of my 69 RR. They have bleeders at the top on each side of the caliper, when bleeding, do I have to bleed both sides?
Thanks!
I believe you just need to bleed the highest bleeder. They build the calipers with bleeders on both ends to work on more custom applications where the caliper might be installed forward or behind the axle or spindle.
You have to bleed both. All of mine had the crossover tube at the bottom. There is no way air can get out. One gets the most out but there still will be some on the other.
You have to bleed both on the Wilwoods, you'll never get all the air out if you don't.
