Body Fender Mounted Turn Signal Indicators
Thank you everyone for the replies. I ordered 3 of them from Aircraft Spruce I only need 1 but for $1.15 a piece I figured get a couple extra. Only $5.00 shipping. Thanks again for the help.
I just bought a pack of 10 NOS GE 330s of ebag for $16.88 that's approx. $1.69 a bulb.
I had taken the bulb unit apart and put it back together before the light bulbs that I ordered had arrived and it worked again a few times before it quit working again. Once the new bulbs arrived, I installed a new bulb, and it still doesn't work. What are we thinking that I need to check? I wiggled the wire that is in the wheel well, it didn't start working.
Needs a good ground to the fender, the lower bracket has some teeth designed to dig through the paint and undercoating on the underside of the fender panel. I will add a separate ground wire using a ring terminal under the mounting stud nut to insure a good ground to the lamp housing.
