FOR SALE Bolt in ready 440
FJ6 v code RR
2:21 AM
Collins Ohio 44826
Feedback: +3 / =0 / -0
Hi I have a all redone ready to go chrysler 440. This has a rv cam with new double roller timing chain and a aluminum toker intake. The heads are harden seats 452. Has big block motor mounts already to go.
I have a set of b body hp exhaust manifolds with gaskets and bolts all redone and bolt on ready. I can sell for extra money to go with the 440.
I also have a 1970 383hp 727 that can go with for extra. If you have any questions please just ask thanks for looking.
Price is $5,500 for just the 440
Price with hp exhaust manifolds is $6,000
Price with everything is $7,000
Location is collins ohio 44826.
I see a new timing chain on it, however it looks from the pics and the carbon ridge shadow it looks like factory pistons- has it been bored or re-rung? new bearing or the crank turned? Is the valvetrain factory or does it have roller rockers as the tall valve covers would suggest? Have the heads been serviced?
Was tore down to the short block cleaned everything checked and regasket and put back together. The heads where cleaned and all valve where cleaned and checked and put back together all new seals. Everything on the short block is all standard bore and standard on the crank. The cam is factory as well as the rockers.
