BOLTS AND SPLINE
moparsquid
6:50 AM
spring valley ,ca.
I have a chance to buy a 8 bolt max wedge crank for a great price but for a few dollars more I can get a lightweight crank from 440 source and im sure its 6 bolt I plan to do a little strip time which would be better also can I get away with using a 23 spline tranny vice 18 spline expensive trannies or could I buy a 23 spline and change over with parts from Brewers thanks
Tranny wise, I would find a decent 18 spline as there is quite a few parts to change to make it an 18 spline. Cost effective wise, its probably better than buying a 23 and converting if that's the way you wanna go 18 spline. I have beat on mine pretty good and my 23 spline is fine, but the hard launches at the track with slicks might break parts eventually. the 23 spline will take a good amount of abuse.
My real max crank is a six bolt, the eight bolt is almost certainly a hemi crank. No big, they interchange. But if i was buying a crank, i would prefer to buy a new one, rather than an unknown-how-abused, fifty yearold one. (And i would take the opportunity to buy a stroker crank!)
Or one of the early (59-61) extended flange wedge cranks... Those used eight holes but they are not threaded...
There is no converting a 23 to an 18. Lots of differences. 23 will hold up on the street pretty well. Drag strip under some abuse. I’ve run a fair amount of mid 12 passes with zero issues. The clutch, tires and weight are the big issues. I have nearly every part to build a slick shifted 18 spline. Every gear is brand new. PM me if interested.
Doug
the part number goes to a 426 max wedge the crank came out of an engine that was in BOB ELLIOTS 63 plymouth
Max wedge & Hemi use the same crankshaft forging, the differences are in the machining... Max Wedge was 6 bolt, Hemi 8 bolt... Lots of parts swapping happened in race cars...
I would rather have a lightweight 440 Crank! New. and with the right pistons & rods
you can keep that mass down.
Me personally I don’t care about light weight as I care more where it’s made and the quality. I’ll take the old crank! Clean it up , check it out , machine as needed and balance to a good rotating assembly and you just recycled another part and let China lose again. IMO
Also there is an 8 bolt steel crank that was used in a big truck application in an industrial 413.
For the crank, the real issue with a factory BB crank is if it is a stock undercut fillet style. As far as I know the Hemi cranks were the ones that used a radius fillet design. Not sure about the "truck" cranks. I used up many stock 440 cranks (7000+ RPM, never broke one, but they eventually cracked, did break a main cap). The alloy would make some difference. IMHO 8 bolt vs 6 bolt doesn't seem to make much difference.
Never heard anyone really complain about the quality of 440 Source cranks, but I don't have one.
Street Hemi cranks had undercut fillet. Kellogg crank had radius fillets. The truck 8 hole crank may extend out the back of engine and won't work in cars. Not positive on that.
Guess I may be wrong, but the '70 street Hemi crank I looked at had radiused fillets.
Other than 8 crank bolts, what was different about a Hemi crank?
im leaning to the 440 source light weight its not to much more and its new and most likely get higher revs
On my RB 505 I went with the 440 source lightweight crankshaft. I chose to go that route for the reduced rotating mass weight as well. So far so good.
Nothing different. Had a chance to buy a Kellogg crank. A dealer closed and my near by dealer took the stock. Called a friend that worked at closed dealer said crank was to bent so they didn't use it.
