Bracket between intake manifold and AC compressor original 1967 GTX
FJ45Dude
New Member
11:32 PM
Arizona
Is this bracket between the intake manifold and the Rv2 Compressor original to the vehicle?
1967 GTX with factory AC.
The reason I ask is that it covers up one of the bolt holes where a typical "dual tab" coil bracket would go. My coil bracket only has one bolt tab. I had always thought this set up was original (you will see a non-original stud vs. the factory bolt where it holds the coil and bracket to the manifold). Thoughts appreciated!
Mine has a bracket there but it also has a mostly complete 68 440 motor in it. So I'm never certain how much stuff on it is original 67 and what might be transferred over from the 68. It has a 69 compressor on it. My bracket appears different than yours and my coil does utilize both mount holes. I don't know which is correct.
A more overall view.
