Braided brake hose
madmopar
7:45 PM
So Cal
Where can I source a set of braided front brake hoses for 68 charger. I have a factory sway bar and late b body rear mounted disc calipers. I thought someone mentioned gm vehicles but I can't recall what models.
Had mine made local, just find a hose/ fitting place that dose DOT lines. The options are endless, like the sheath color banjo ends ect.
I have used the Russell hoses on my cars since they have the DOT tag on them. The DOT tag is required here for aftermarket hoses on street cars.
Summit sells them.
I see summit sells them but I thought I needed a certain length and type because of the way the calipers mount when using a factory sway bar on a 68. I know Dr diff sells a set specifically for this application but their kinda of pricy. I could of sworn that I heard that I could source a set from a camaro or corvette or something along those lines.
