Hey guys , anyone ever had a rear brake drum rub against the backing plate only in one area , and what was your fix ? 11x2.5 brakes rub spot is 4” left side of center on passenger side , changed axle no deference! What as ye !
No visible but possible on 50 + year old rear ! Will consider !Is the backing plate bent in a little bit in that spot? If so, tap it out with a hammer.
Okay , axle I have , backing plate I will have to find , Cranky lives near me , relatively speaking , will ck your info , thanksYou can just rotate the two or three studs from its current position. If it rubs in the same spot it's probably the backing plate. New spot it's the drum, assuming the axle is not bent.
