steve from staten island
- 1:58 AM
- Sep 24, 2012
- staten island,ny
This car is seriously beating me down. Its never ending. I installed the new dual diaphragm booster, changed lines, bleed brakes. I reattached the stop light wires and found out the left brake light is not working. No power to the terminal. I took off the drivers side kick panel and checked it and there is no power coming out of harness
The right side has juice. The left feed is a green wire. When you put on he hazard flashers the left rear side works when you step on the brake the lite stays steady. When you turn off the hazard light, same problem.
I cant trace were that green wire goes. The harness connections are all tight.
Brand new complete car harness from Year One.
I checked as much as i could and i have the color wiring diagram.
After fooling around for so long I'm thinking its the hazard switch
What gets me is everything else works, the right brake light included. What gives any thoughts are appreciated
