This is another post about my age-old brake demon and figured I'd post a new one that gets to a particular matter to keep things simpler. I'm thinking one or more has the smarts on this pedal ratio thing. I converted from front drums to disks and manual to power. I gather that the pedal arm has two holes, one for manual and other is lower, supposedly for power brakes. Except that connecting the rod to the booster using the lower hole cocks it (rod) way off line so quickly nixed this staying with the hole it had been on since the fore and aft action for the rod is on alignment. I had to shorten the threaded rod substantially to bring the brake pedal down as it had been way high. There must be some geometry or maybe trig here that is involved and maybe shortening the rod created another problem with necessary rod travel. What's bugging me with all the hunting to fix the intermittent gremlin is never taking this into account with the install simply using the pedal as it was setup for manual brakes. My guess is the return travel is incomplete allowing the booster to stay partially activated...just a wild guess. Thanks.
