Brakes
Ed Price Jr
5:53 PM
Topeka, Kansas
I was wondering, do you have to have all of the coils in your Brakeline, on the right front of a '67 R/T when you have converted it to a disk setup? The line for the manual drum brakes had several coils in it, just inside the engine compartment.
I believe that the are there for the slight flexing during braking and vibration. That's my take on it. Myth? Theory ? My best guess ?
These are the steel lines in the engine compartment , before the tab where the rubber lines connect. I wondered if it wasn't something as common as the factory having excess line when they installed them and just coiled them. The disc brakes have a proportioning valve, so I'm not sure that I would need the lines coiled.
:xscuseless:
If the lines were short and straight, the motion of the car would eventually crack the brake lines; the continual flexing would fatigue the metal and eventually break it, just the way a spoon bent back and forth repeatedly will eventually break. By forming the brake line into a coil, the flexing in any one section is very small, and so puts almost no strain on the line.
Glad I'm reading this before I plumb my car, so the MC lines the only ones you really want coiled.
