Break into a 1964 Fury trunk?
remotored
8:57 AM
KoP, PA
The key for the trunk is worn and soft and will not turn the lock.
In which manner can I get into the trunk causing the least amount of damage? Drill the lock?
I tried putting in the key and turning with a flathead, but that only put a fairly deep notch into the key.
remove the rear seat back and bottom and crawl through the back and open the trunk from the inside
