Broken Emblem Fix
71SandbugCharger
2:01 AM
California
I tried JB weld on this and it broke again. I’m thinking of adding a little metal on the back, and then Jb weld, but that may make the emblem sit higher in mounting. Any good suggestions for bonding the two pieces together?
Luckily the posts are still good.
You could also use two sided tape. Takes a little trimming but can work out ok.
Take a dremel and groove the back side well and epoxy two pieces of wire in a x pattern
That's what i do. I use thin pieces of tin or sheet metal to bridge across the break area. Gives the jb weld a larger surface area to bin and much more durable.
