Broken studs on emblems? Good fix suggestions
dnlsctt
1:09 AM
Austin, Texas
i have 2 emblems with broken studs and was curious if there’s any good hacks or fixes out there to salvage the emblem? I have scrap emblems that I can glue studs on but I’m not sure it would work. Any ideas would be greatly appreciated
I fixed the side emblem with some small screws and some loctite. Drilled some pilot holes then tapped them out. Here is my post.
https://www.forbbodiesonly.com/mopa...1966-belvedere-2.170448/page-2#post-911259928
I also repaired my sail panel trim by drilling it out the same way and used a 1/4 20 bolt that I filed down to the same profile as the post. Once done I then used flux and soldered it into place to make sure it stays.
Works like a charm, won't loosen up and seals the hole from moisture.
