New
Cam = $360.00
Lifters = $500.60
Total = $860.60
Endure-X™ Solid Roller Lifter: Chrysler V8 383-440, 426 Hemi
Product Representation: Actual part may vary based on configuration ordered.
Part: 830-16
Price: $500.60
Weight: 5.25 lbs
Quantity: Application – Chrysler V8 383-440 and 426 Hemi
Diameter: .904″
Weight: 122g
Pushrod Seat Location: Centered
Oil Hole vs. Axle
Seat Height 1.65″
With a pushrod seat located .140" deeper than standard location, these Solid Roller Lifters from COMP Cams® are engineered to withstand the demands of aggressive cam lobe designs and increased RPM ranges. They feature a wear resistant tool steel axle and precision sorted needle bearings. Endure-X™ Solid Roller Lifters are heat treated, machined to ultra-high tolerances and fully rebuildable.
Patented link bar assembly combines the benefits of a removable link bar with the safety of a captured link bar
Needle bearings are precision sorted by size to evenly distribute loads, which prevents premature wear and failure
Durable axle is made from wear resistant tool steel to prolong the life of the roller assembly, especially in high RPM applications
