Can put gtx in reverse while driving.....
BLANCK88
2:34 PM
any reason I can put my 69 gtx accidentally into reverse while driving forward????
No reverse or neutral lockout on factory floor shifter or you have your hand resting on the button during up shifts. Not a good idea.
No factory neutral or reverse lockout on floor shifter? Terrible idea...yes it's automatic
Mal-adjusted shifter mechanism. Probably an easy fix. :thumbsup:
I actually had the ratchet part of a stock slap stick fail. The trans valve body was modified so the 727 was always shifted manually. The slap stick would go past 3rd and N right into reverse at 60 mph without touching the button if it felt like it. I quickly replaced it.
These guys have shown that you probably will be ok....
