Bens69PlymouthSatellite
I have had stuff written in here before about what direction I should go with a rebuild and you were all very helpful,so here comes another one, I have a 69 440hp magnum.If the engine needs to be bored over,.30 over is all im doing if I can,the stock engine should make 10.1 compression right? I wanna stay on pump gas and around that compression,how would this work out,Edelbrock performer rpm heads 84cc, 2.14 in.,1.81 ex., stock crank,and rods, speed pro pistons,3.73 gear,2800-3200 stall torque converter, comp hydraulic roller cam,rpm range 1800-5800,274in. 282ex. @.050 224in. 230ex. lift .538in./.534ex. 110 lobe sep. and 1.5 rockers,and edelbrock performer manifold,1500-6500 rpm,holley 770cfm, does anybody have any suggestions,any help with cam selection? If I dont go with this im gonna use the eddy top end package,looking for about 500hp,wont complain about a little more,or less,I would be happy with a stock rebuild,with slight cam and eddy heads,any help with estimated compression? I appreciate all of your tolerance for my questions,I am pretty new at this still.
