Can someone ballpark a good engine rebuild?
Bens69PlymouthSatellite
11:39 PM
IN.
I have had stuff written in here before about what direction I should go with a rebuild and you were all very helpful,so here comes another one, I have a 69 440hp magnum.If the engine needs to be bored over,.30 over is all im doing if I can,the stock engine should make 10.1 compression right? I wanna stay on pump gas and around that compression,how would this work out,Edelbrock performer rpm heads 84cc, 2.14 in.,1.81 ex., stock crank,and rods, speed pro pistons,3.73 gear,2800-3200 stall torque converter, comp hydraulic roller cam,rpm range 1800-5800,274in. 282ex. @.050 224in. 230ex. lift .538in./.534ex. 110 lobe sep. and 1.5 rockers,and edelbrock performer manifold,1500-6500 rpm,holley 770cfm, does anybody have any suggestions,any help with cam selection? If I dont go with this im gonna use the eddy top end package,looking for about 500hp,wont complain about a little more,or less,I would be happy with a stock rebuild,with slight cam and eddy heads,any help with estimated compression? I appreciate all of your tolerance for my questions,I am pretty new at this still.
Don't count on the factory Magnum 440 to be at 10:1. I am building a mild 440 now using the KB 237 pistons, 915 heads and a shim gasket and it CC'd at 10.0:1 (79.5 CC chambers). Now, the KB pistons have some large valve reliefs in them but they are at the six pack compression height - 2.065" vs the Magnum pistons, which are 1.990" I think. I recommend you CC everything so you know what you have.
Where do the 3.73 gears come from? It's a non stock ratio so I'm just curious.
I assume you will use the Performer RPM intake.
I would think that roller cam should work well with the Eddy heads.
The 3.73 gears were motive gears alot of people told me to go with 3.55 gears,or 4.10,not really sure what my real logic was behind the 3.73 except maybe with a little taller and wider wheel in the back they may bite a little better,and still maintain some level of fuel economy and not be revving so high on the expressway cruising at 65mph like a 4.10 or 3.91,do you think they are a bad idea? I actually think I may end up going with the eddy power package,just saw a video of it making 520hp on a dyno and 560ft lbs of torque,and its the easiest to work with,no real guesswork,I would still cc everything as you suggested,I dont need a 11.5.1 12.1 compression on this car 93 octane is expensive enough,should I go with 3.55 or keep the 3.23 I have now? And will the 741 rear I have take that much power?
The gears will depend on how you plan to use the car and should be tied to the engine power band. For strict 1/4 mile use you want to be going through the lights right at the top of your power peak. For freeway flying at low RPM you want 2.73's. Personally I think 3.73's are leaning toward the 1/4 mile side of the equation and minimal freeway driving.
I knew a guy that used to run his 67 Formula S 383 Barracuda on the bottle with slicks on a 3.91 741 case. Although he had no problems I still wouldn't go out of my way to install one, but assuming you will use the car with street tires the 741 should be just fine.
Yeah, 11.5 - 12:1 is too much so I'd shoot for a max of 10:1. Using the Eddy package will take a lot of guesswork out of the build since all components were selected and tested on a dyno.
I really selected the gears based on what a friend of mine who has a 528 Hemi charger explained to me about how he has 3.91 in his right now and hates them with a torqueflite trans, wishes he went 5 speed, so instead he is going down to 3.73 gears so he has a little more *** off the line and can still just cruise decent.He said based on the fact that I do race a little on and off the track(If it$ worth It!$$) He said at 550 estimated hp and 580 tq I should maybe look at the 3.73, If I hate them I will drop down to 3.55! thanks for all the help Meep and Will!!
I've had a 741 w/4.10's for the last 18 years with 360's rated at approx near 450 HP/400 lbs. of torque pounding it over the years.
New engine is in and expected to see over 500 HP / 470 lbs tq next year. IF I break it, you'll read about it, though I doubt it. LOL!
OK, I can't stand it, I tried to restrain myself, but.....
My engine builder gave me a good ballpark, but he was off by a couple grand...:rolling:
I'm so sorry.....
Thanks for the help so a 741 case will be fine im sure. Why do people refer to it as the crappy 8.75, The same guy I refered to with the 528 hemi is making 630 hp rear wheel hp and he has a 741 says he has used a ton of them,never had an issue even laid down a 9.8 second car on one,is that pure luck? I knew the 8.75 was tuff but never thaught it to be that tuff,Thanks for the help!!
The 741 has the smallest pinion.
Sorry, I should have noted that I have 742 gears in the 741 case. A 489 is the biggest pinion gear -8-3/4 rear. In theroy, the larger the gear, the more power it will hold.
I have a buddy that used to have a all steel 69 Dart w/a BIG roller cammed, Indy headed 500 cid engine laying down a best of 9.2 in the 1/4. This is when the rear finally gave out. The rear was also stock, no bracing on it, no nothing added, just S/S springs moved inboard and a pinion snubber.
Mine is all 741 posi so I will most likely end up going with the Eddy power package,which I am sure will test the tensile strength of the 741! I will let you all know if it becomes an unsightly hood ornament for some POS Chevy or Ricer!
That's interesting info! New life to 741's!
